27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Swept Blend for Basin
24 Posts No Rating |
Hi there,
I was hoping to use a swept blend to create a fairly simple basin form - using a quarter rotation from one profile to another, then mirroring to create the final element out of the 4 quarters.
The result is fairly bizarre! - see attached. Rather than a smooth oval form, I've ended up with a Rolling Stones style set of lips!
Any suggestions why the model is performing like this and how I can fix it? Or an alternative method.
Thanks very much for any help
T
Couple of points.
Make sure your sketch path lines will transition from one quandrant to another correctly. i.e. does the line need to terminate perpendicular to the axial lines or does the angle it touches at the axial lines need to be adjusted ensure the profile sweeps smoothly through.
Also, make sure the location of the sketch profile and the sketch profile itself is correct to allow a smooth transition across the axial lines.
Edited on: Fri, Oct 27, 2017 at 5:01:21 AM
Thanks Beaucoupnice - I'll give that a go.
[Revit MEP 2010] Stuck on VOID SWEPT BLEND |
Thu, Jan 6, 2011 at 9:12:14 PM
Swept Blend |
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!! |
Mon, Jul 28, 2014 at 3:31:14 PM
cannot rotate the reference plane of a swept blend |
Tue, Feb 23, 2010 at 6:22:35 AM
swept blend with more than 2 profiles |
Sun, Nov 18, 2012 at 5:21:23 PM
