Forums >> Revit Building >> Technical Support >> Cannot Edit Tree Height
Fri, May 26, 2006 at 10:39:20 AM | Cannot Edit Tree Height
Kalvin
I am not trying to edit the AccuRender tree...just the representational one when I am in a normal 3D. Even when I type a new height to my tree in its properties, the wireframe model stays the same. Any advice?
Mon, May 29, 2006 at 10:47:36 PM | RE: Cannot Edit Tree Height
eldados
eldados Avatar
4.5 Stars: 8 Votes
some trees are just an Autocad block that was brought into an RPC family. onto this dwg you can attach an accurender image and that is a set size, i don't think you can change it, but if you need to see the tree bigger in shaded view (or any other view but render) go to the family and scale up the tree there.
Integrator
KarelCAD
Tue, May 30, 2006 at 12:21:21 AM | RE: Cannot Edit Tree Height
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've metioned this quite frequently... Nest this planting family into a blank planting family and save and load it in. This allows the ability to scale the dwg representation in the project. No need to lock or constrain it at all. HTH.
Thu, Oct 3, 2013 at 1:38:21 PM | Cannot Edit Tree Height
archigrafix
5 Stars: 4 Votes
We have just made a video tutorial showing how to adjust revit trees in height. It shows how to quickly create several families / types in different sizes, how they change in plan and elevation and also how to change it in the project.
The link to the video is under Tutorial / Parametric Scale on the following page: archigrafix revit trees .
Please send us your comments.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
trees
Wed, Jul 3, 2013 at 1:55:49 PM
Tree
Fri, Jul 16, 2010 at 4:19:25 AM
rpc tree
Tue, Mar 31, 2009 at 12:01:03 PM
Tree library
Mon, Oct 9, 2006 at 4:39:22 PM
Elements missing from elevation when behind a transparent tree
Tue, Jan 27, 2015 at 7:00:25 PM
Page generation time: 0.2665
