22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> How to create this type of roof
Hai guys, this is my first time post..anyway how to create this type of roof, is there any tutorial. Thank You
I using Revit 2016
Here is how I would do.
Draw a standard pitched roof to the plan size you need (ignore the dutch gable). i.e. draw sketch lines along the line of the eave and give each sketch line the correct slope angle so when the roof generates, it creates hips and ridge lines. Then use an in place family to model the dutch gable. You can make it using three parts. First extrusion to shape the pitched roof buildup (you can use a void to cut the extrusion at the angled roof face), second extrusion to create the external wall beneath the roof and the third part to form the barge board.
HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN |
Fri, Sep 20, 2019 at 11:10:56 PM
Create Roof Family Object |
Mon, Nov 21, 2005 at 7:10:42 PM
Create pie shaped roof, but no curve |
Wed, Jul 4, 2012 at 7:21:19 PM
Roof by footprint won't work in view |
Fri, Jul 9, 2010 at 12:10:55 AM
Roof Framing For Sloped Roof |
Tue, May 5, 2015 at 5:48:41 PM
