Forums >> Revit Building >> Technical Support >> mullion join at angled mullion 2017
Thu, Oct 19, 2017 at 11:44:05 AM | mullion join at angled mullion 2017
ledgewood33
i have a storefront/ curtain wall and in elevation i have the perimeter mullion at an angle. i have a horizontal mullion coming into the angled mullion. i cannot get them to join cleanly. i am attaching a screen shot of what i am talking about.
Sat, Oct 21, 2017 at 11:53:54 AM | mullion join at angled mullion 2017
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Some options:1) Delete the curtain wall gridline and try again. It looks like some of your mullions above and below appear to join correctly. Maybe also try deleting the horizontal one and the vertical one near it (The proximity of the vertical one may be causing confusion). Then add back in the horizontal one and see if you can make the join work, then add the vertical back in.
2) Delete the mullion that does not work but keep its gridline. Then model in place the mullion using align tool to align faces.
3) Delete whole curtain wall and create whole curtain wall as generic model family. Glass/ mullions et all. Load in and place correctly.
Horiz mullions wont clean up because of angled corner mullion
Wed, Oct 1, 2014 at 8:43:20 AM
Mullion Will not Join IF Mullion is Less Wide than Tall
Tue, May 19, 2015 at 11:03:13 PM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
cleanup horizontal mullion at corner mullions, again....
Wed, Jan 8, 2014 at 11:14:49 AM
Page generation time: 0.1366
