Forums >> Revit Structure >> Technical Support >> framing elevation tag
Tue, Oct 17, 2017 at 9:55:02 AM | framing elevation tag
ks4916
Hello Allas you will see in the attached pic, i was able to modify the system families for the framing elevation tag, however the problem i am having is locking the labels to remain horizontal regardless of orientation of the framing tag. obviously i do not have an issue with the tag if the framing elevation is either vertical or horizontal. I have tried adding a angle parameter to lock the angle but i think the angle is getting locked to the reference plane in the family itself. I have also tried using the parameter within the original family to fix the position but to no avail.I have gotten everything to work in the tag except the labelsI am hoping all the revit gurus out there can provide some guidance as how to fix thisThanks in advance
Thanks in advance
Regards
Kevin
Tue, Oct 17, 2017 at 5:59:46 PM | framing elevation tag
I don't understand why you did this.  The standard tag always remains normal and you could have modified that to have this look.
Tue, Oct 17, 2017 at 7:28:13 PM | framing elevation tag
ks4916
well as you know every company has their own set standard and sometimes the OTB families are not sufficient or desired, that is why we all spend time modifiying system families to suit the company and how they want to show things.
so in my case the OTB framing elevation tag was not desired and they wanted to show it differently as shown in the pic originally up loaded.
Moving forward, as mentioned before i have gotten everything to work but i want to keep the text and the line inside the circle horizontal.
while the orientation of the text is not preferred, it is accepted until I can find a way to fix it, unless someone out there can guide or provide me a solution
Thanks in advance
Thanks in advance
Regards
Kevin
Wed, Oct 18, 2017 at 10:25:04 AM | framing elevation tag
I think you miss-understood.   The OTB tag text and line always remains horizontal which is what you say you want.  Just modify that to include the other corners of that pointer.
Wed, Oct 18, 2017 at 11:05:46 AM | framing elevation tag
ks4916
sorry i misread.
yes if i check off the fixed position box in the system family the text remains the same. it is the line within the circle that i am having trouble keeping horizontal.
Thanks in advance
Regards
Kevin
Fri, Jul 18, 2008 at 3:59:53 PM
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Adding length parameter to framing tag
Sun, Jul 18, 2010 at 4:19:26 PM
Structural framing tag
Mon, Apr 5, 2021 at 1:29:32 PM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
Page generation time: 3.6533
