8 Users Online (6 Members):
Forums >> General Discussion >> Revit Project Management >> Shared coordinates and IFC link positioning
8 Posts No Rating |
Hello,
I have this issue:
Some models share same coordinates that are quite far away from origin. Survey point stands at 000, project point at A1 grid intersection (some point on planet with many numbers . I made this possible by acquiring coordinated from dwg topography. Everything works.
However, then I link IFC (there are no settings in link IFC dialog), it places linked file (exported from Civil 3D) much further than it should be, probably twice as far. I tried exporting my models to ifc and putting it in tekla bim sight – everything aligns perfectly. I even opened IFC in Revit in a separate file, checked coordinates, everything is correct.
I tried linking revit (with IFC open in Revit). Every possible insertion option gets me the same result. I tried to move project base point to know location (A1 intersection point). Had super difficult time. Revit can not move unpinned project point more than 19km.
Am I missing something?
Is there a workflow for these situations?
Thank you.
Hey man, I have the same issue.
Yay.
Thanks
Cristy
REVIT2018 IFC link positioning / coordinates |
Thu, Apr 26, 2018 at 4:03:03 AM
Shared Coordinates |
Sat, Mar 6, 2010 at 10:06:14 PM
shared coordinates |
Wed, Feb 18, 2009 at 2:24:57 PM
Shared Coordinates while linking Dwg into Rvt |
Thu, Jun 5, 2014 at 12:06:32 PM
Shared Coordinates - saving after publishing |
Mon, Apr 27, 2009 at 4:45:34 PM
