15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Disappearing Act
Several objects in my model are disappearing everytime I open the project. In fact, everything new I put in disappears. I can usually make them show when I go into the door schedule, select one of the doors that is hiding and select "Highlight in Model", then everything re-appears.
They do not show when you "Reveal Hidden". The do not show in any view - Elevs, Plans, 3D. They are not in different phases. They are selected to appear in the "Graphics/Visibility".
Danni D. Waddell
Designer
Tevis Architects |
Maybe a graphics card issue.
I agree with WWHub. Try turning on/off your graphics acceleration. Check your GPU is supported by Revit on the AutoDesk website.
You are going to have to explain yourselves. How does the graphics card have to do with this? The products show once I tell the door schedule to highlight a door in the model. Before that there is simply nothing there, EXCEPT there is a void where the door is.
Danni D. Waddell
Designer
Tevis Architects |
Believe it or not - Graphics Cards can cause this sort of problem.
You have not given us a lot to go on. What Revit? and what updates are installed?
What is your discipline setting for these views?
You have been around for a few years so I think you have been using Revit for awhile.
Revit 2018
I don't know if any updates have been installed. I have not accepted any new updates so I doubt any unless they are automatic.
Architectural
Danni D. Waddell
Designer
Tevis Architects |
are the items o a workset thats turned off?
2 X 2 ACT ceiling in Residential Template |
Sun, Nov 23, 2008 at 8:56:07 PM
disappearing act |
Wed, Sep 17, 2008 at 10:47:01 AM
Disappearing Callouts |
Thu, Feb 14, 2008 at 11:36:27 AM
window frames disappearing |
Thu, Aug 18, 2005 at 3:05:08 PM
2x4 ACT CEILING DISPLAY ISSUES |
Tue, Dec 4, 2007 at 10:02:28 AM
