Forums >> Revit Building >> Technical Support >> temporary dimension disappearing when converting it to permanent dimension
Wed, Sep 13, 2017 at 1:49:26 PM | temporary dimension disappearing when converting it to permanent dimension
hebdrafting
hebdrafting Avatar
I am teaching (but by no means an expert) a class in Revit.  We are using Revit 2018.  Some of my students are having a problem with a temporary dimension disappearing when trying to convert it to a permanent dimension.  It only happens on occasion, but when it does, the only way I have found to correct the problem is to copy the entire project into another new project file.  Even this only fixes the problem for a short while.  Moving the file to another computer does not solve the problem.  This problem also happened some last year with Revit 2016.  I have not been able to find anybody else mention this problem.
Thu, Sep 14, 2017 at 6:35:43 AM | temporary dimension disappearing when converting it to permanent dimension
I am pretty confident that this is a process error.
Are you sure that dimensions are on in the VG settings for that view?
Thu, Sep 14, 2017 at 9:37:24 AM | temporary dimension disappearing when converting it to permanent dimension
hebdrafting
hebdrafting Avatar
I think I discovered the problem.  The student was hiding the category and not just the element.  Thank you.
Edited on: Thu, Sep 14, 2017 at 9:42:10 AM
Thu, Sep 14, 2017 at 9:48:30 AM | temporary dimension disappearing when converting it to permanent dimension
Look at image:
Pin Detail elements to move with Nearby Walls etc
Fri, Aug 13, 2010 at 7:12:19 PM
Reference Plane Dimension
Sat, Aug 20, 2005 at 7:33:46 PM
adjusting grids using temporary dimensions
Thu, Nov 22, 2012 at 12:05:29 AM
2013_curtain wall grid pattern
Wed, Nov 21, 2012 at 3:59:18 PM
Wed, Jul 1, 2009 at 10:50:50 AM
Page generation time: 0.1681
