Forums >> General Discussion >> Revit Project Management >> curtain wall
Tue, Sep 12, 2017 at 9:14:50 AM | curtain wall
Lrhvam
Hallo everyone
I have a issue that keeps bothering me, hope you can help.
I am almost always using curtain walls instead of windows and doors. they are easy to work with BUT - if i place a curtain wall as a window in my brick wall the brick material will not show in the hole. If i paint brick materiale in the whole it will be on the whole wall face, so i have to split the wall where the coutain wall is placed - any way around this?
I want the wall to have brick on the outside and white indoors - i do not want to split all four faces where the curtain wall embeds the wall.
hope i made myself clear!
Tue, Sep 12, 2017 at 9:38:11 AM | curtain wall
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Here is an AutoDonk link that shows workarounds for their stuffup.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Materials-do-not-wrap-at-curtain-wall-openings.html
Wed, Sep 13, 2017 at 1:15:22 AM | curtain wall
Lrhvam
thank you!
i just don't fix my problem with two different materials in the face of the hole. how do i do this without having to split all four wall faces with every window placement?
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall
Sat, Jan 10, 2009 at 10:01:35 AM
Page generation time: 1.2570
