Forums >> Revit Building >> Technical Support >> Faceteted Aphitheatre Conceptual Mass
Tue, Sep 12, 2017 at 6:47:07 AM | Faceteted Aphitheatre Conceptual Mass
tdrdesign
Good morning
My firm is in the process of desining a new open amphitheatre shell which contains several facets and is not symmetrical in any way. We built this file through sketchup and imported into Revit as a Conceptual mass which works great. The issue I am having is how to easily apply a steel endoskeleton to the mass that will nicely follow the interior joints the facets are creating? Any assistance would be appreciated.
Wed, Sep 13, 2017 at 3:07:57 AM | Faceteted Aphitheatre Conceptual Mass
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hard to answer without more information like some pictures of the Ampitheatre.Using conceptual masses is fine to portray tricky non-orthogonal shapes at a concept level but when you move into a more technical level like considering what the structural support is, masses become a little too simple for effective use.
Fri, Sep 15, 2017 at 11:47:37 AM | Faceteted Aphitheatre Conceptual Mass
tdrdesign
I have attached a few pdf's of the proposed exterior shell for your reference. I have determined that I actually have two issues..
1. Properly laying out the structural elements to suit the shape.
2. Having all the wall/roofs (which are walls) join properly instead of all birdmouthing as they currently are showing.
Thank you,
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:05 PM
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:36 AM
Scaling Conceptual Mass
Mon, Oct 11, 2010 at 7:34:51 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Conceptual Mass: Revit Architecture 2012 (Trial V.)
Mon, Jun 30, 2014 at 7:20:05 AM
Page generation time: 1.6774
