Forums >> Revit Building >> Technical Support >> Family Components showing in Elevation behind cutline
Fri, Sep 8, 2017 at 10:35:38 AM | Family Components showing in Elevation behind cutline
jsel13
REVIT 20172.1
Im trying to save memory in my file so instead of modeling all the cabinetty in out kitchens and bathrooms, i am using 2D linework within detail families to represent each elevation
for my kitchens, i started with a generic model, i added work planes for each wall, then i added 2D detail families with the kitchen elevation linework for each elevation
when i load it into my project and cut a section, i see the elevation im supposed to see as well as the one behind the cutplane
can someone tell me why i keep seeing this elevation? i cant make a 2D detail a SHARED file, so each individual elevation file is not selectable in the main model to turn it off. i'm ableto turn off the appliances because those are 3D specialty equipment familes that are shared, so i can select them to turn them off in my model
i'm stumped and could use some help
thanks!
Fri, Sep 8, 2017 at 2:10:10 PM | Family Components showing in Elevation behind cutline
I really don't like your process.  So many good 3D cabinet families are available and at no real cost to file size.
This sounds like 3D linework, not 2D.
Fri, Sep 8, 2017 at 4:23:53 PM | Family Components showing in Elevation behind cutline
jsel13
sorry you dont like my process, but i've done it before and it has worked just fine. its also not 3d linework. and the memory will increase when i input the kitchens in 250 units.
How to hide everything below cut line in elevation?
Wed, May 4, 2011 at 3:30:28 PM
Sink family showing through extrusion in elevation
Thu, May 21, 2015 at 4:59:51 PM
help with family parameters to show colours in elevation views.
Tue, Nov 30, 2010 at 7:14:20 AM
Joists parallel to section cutline don't show in wall section
Fri, Jan 24, 2014 at 4:23:13 PM
Door and Window Frames not showing in Elevation
Thu, Dec 17, 2015 at 4:34:06 AM
Page generation time: 2.3515
