Forums >> Revit Building >> Technical Support >> Color schemes only solid color no patterns
Fri, Sep 1, 2017 at 8:09:01 PM | Color schemes only solid color no patterns
danostruct
Im working in 2017.2. Using dRofus to add parameters to rooms in the arch model and using color schemes to display rooms with different loading types. Got           everything working great. I select solid colors to display rooms and it works no problem. Then all I change is to a pattern and nothing appears... it just goes blank like there was no pattern or color. (?!) Makes no sense. Any ideas?
Mon, Sep 4, 2017 at 7:24:54 AM | Color schemes only solid color no patterns
Elnazer2
4 Stars: 5 Votes
the only thing i can think of is that you are choosing tight patterns thats showing like if it's solid
Color Schemes
Thu, May 23, 2013 at 12:35:43 PM
area color schemes
Fri, Jan 27, 2012 at 2:36:28 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Color Schemes
Wed, Jun 3, 2015 at 3:15:18 PM
"System Color Schemes" not regular color schemes in Elevation or Section views
Mon, Mar 22, 2010 at 6:00:00 PM
Page generation time: 0.2613
