Forums >> Community >> Newbies >> Family HELP
Thu, Aug 17, 2017 at 4:02:35 PM | Family HELP
swooll3
1 Stars: 1 Votes
Hello,
I just created an electrical panel and want to add two more things but can think of the best approach for either.
First- I would like to have dashed lines 1/8" in from each side of the panel. I figured I would make a detail item in a separate family, then nest it in to my panel family. I would then  like to make a formula stating that it always needs to be that 1/8" inside of each side of the panel whether the panel shrinks or gets bigger.
Second- I would like to add an access on the top and bottom of the panel and would be able to change the size and where it sits on the top as well as the bottom of the panel.
Thanks
Fri, Aug 18, 2017 at 2:23:24 PM | Family HELP
CDWdavid
5 Stars: 5 Votes
Here are my suggestions:
The first one, you can use symbolic lines with locked dimensions.
The second one, you can create parameters to control the size of those panels, and using visibilities to show them either on the top or bottom or both.
Tue, Aug 22, 2017 at 2:21:15 PM | Family HELP
swooll3
1 Stars: 1 Votes
Awesome. Thank you for the reply. I created a panel and made access doors on it.
How would I get it to let me change the size of the access as well as change where it sits on the top, bottom or both. The access door position varies. It isn't always in the middle on the top. Sometimes it is in the bottom right corner, or bottom left, etc.
Tue, Aug 22, 2017 at 8:52:35 PM | Family HELP
shafiqmohd143
HI
    GOOD MORNING EVERYONE . I DOOWNLOAD A METAL ROOF FROM REVITCITY .I WANT EDIT IT BUT I'M UNABLE TO DO .
Wed, Aug 23, 2017 at 2:22:50 PM | Family HELP
CDWdavid
5 Stars: 5 Votes
Hi Swooll3,
Try to add Yes/No instance parameters for each panel to control the visibility.
For example, you can create a top panel, with the "Type" parameters to adjust the width and length, then, using the "Instance" "Yes/No" paramter for turning the top panel on and off.
Wed, Aug 23, 2017 at 4:40:13 PM | Family HELP
swooll3
1 Stars: 1 Votes
So once I create those instance parameters to change the dimensions on the access door, I won't be able to position it on the panel correct? Will it just grow from the center of the panel itself? I am just so lost on being able to change to size of the door and move it's position to wherever I want on the top?
Or can I create an extrusion and control one side of the width and the other side of the width separately? Sorry, I am very new to family building so I don't know all of the exceptions.
Wed, Aug 23, 2017 at 4:41:20 PM | Family HELP
swooll3
1 Stars: 1 Votes
So possibly create an extrusion the exact size of the panel then tell each side of the access door to go so far off of each side of the panel?
Thu, Aug 24, 2017 at 11:51:42 AM | Family HELP
CDWdavid
5 Stars: 5 Votes
That's the beauty of using parameters.
You can create reference planes, then create dimensional parameters to flex them to make sure they work as your intent. Also learn how to lock those dimensions. For example, the top of the panel is 2'x3' locked to the reference planes, the access can be 1" away from one side lock it, with top-width as flexible parameter; then 3" from another side with top-length parameter.
It would be fun.
Good luck for this brave new world!
Thu, Aug 24, 2017 at 11:57:20 AM | Family HELP
swooll3
1 Stars: 1 Votes
Awsome. I will go try and tackle it now. Thanks again for your help!
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family?
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3
Mon, Jan 19, 2015 at 2:43:21 PM
Page generation time: 3.8597
