20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> INCONSISTANT COLOUR WHEN PRINTING
So here is the issue, we use colour fill in our walls and assemblies to show fire rating magenta is 1 hour.
we are printing sections and of the 5 sheets only one shows the colour fill as purpple the rest are magenta.
does not mater to which printer we send it or if it is to a pdf and then print the same sheet is always purple.
the preview shows it correctly even trie an image just of one of the sheeted views same result the fill is purple.
all the view use the same view template and show correctly on screen and in pdf.
just the on sheet and the 2 views are affected.
Thank you
ARe you printing directly or from the PDF? If not from the PDF, then try that.
Colour Printing techniques |
Wed, Aug 23, 2006 at 7:14:17 PM
Colour of wall when printing |
Tue, Dec 13, 2005 at 5:00:48 PM
Changing the Colour of a Material |
Fri, Nov 16, 2012 at 3:21:06 PM
Elevation Colour Scheme |
Wed, Aug 6, 2014 at 3:55:15 AM
Colour fills on sections? Revit 2008. |
Tue, Feb 10, 2009 at 8:32:39 AM
