Forums >> Revit Building >> Technical Support >> sort door schedule by level without adding "level" column?
Mon, Aug 14, 2017 at 6:00:15 PM | sort door schedule by level without adding "level" column?
ccabral3
I'd like to sort my door schedule by level and check "header"... however when I do this, it adds a "level" column as well. This is extremely redundent imo. Is there a way to take the "level" column out of the schedule without loosing the sort by level and header? See attached image.
TIA
Tue, Aug 15, 2017 at 1:08:42 AM | sort door schedule by level without adding "level" column?
tim123
4 Stars: 19 Votes
In the Formatting part of your door schedule you have the option of making 'Level' a hidden field.
Tue, Aug 15, 2017 at 11:27:04 AM | sort door schedule by level without adding "level" column?
ccabral3
Perfect! Thank you Smile
"Schedule Level" Parameter in Plumbing Fixture Family
Thu, Jul 3, 2014 at 2:32:51 PM
Top of column elevation in schedule
Wed, Jul 15, 2009 at 3:52:03 PM
Level Schedule
Mon, Feb 11, 2013 at 1:30:12 PM
Can't insert doors/components in level
Thu, Apr 14, 2011 at 11:20:19 PM
scheduling walls per level
Thu, Feb 12, 2009 at 1:19:14 PM
Page generation time: 2.6841
