Forums >> Revit Structure >> Tips & Tricks >> Support of Excavation drawings within a revit model
Mon, Aug 14, 2017 at 1:52:19 PM | Support of Excavation drawings within a revit model
arcticnyc
Hello guys, I try to transfer even SOE in Revit model. here are a few questionsHow to exclude soldier piles from column schedule? Same thing to lagging? How to make it like two different projects within one model or this is a bad practice? Should I just start a new project and underlay existing model?Thank you!
Sun, Aug 20, 2017 at 10:35:49 AM | Support of Excavation drawings within a revit model
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
I'm unsure what SOE means, perhaps you can elaborate?To exclude anything that is created from the same family such as a pile, you need to somehow differentiate it so the schedule tools can exclude it from the selection process. You could do this by adding a parameter, by completing an existing parameter or even by copying and pasting that family as new family with a different name.I personally like to keep all work in one model, that way I don't have the problem of linking one model into another and all the associated issues that arises from that.
Navisworks - Create Phases for Excavation in 4D Schedule
Wed, Aug 31, 2011 at 7:39:07 AM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:00 PM
Creating Drawings of Components for a Model
Wed, Jan 30, 2013 at 12:14:03 PM
How to easy measure the excavation mass in REVIT?
Tue, May 26, 2009 at 5:03:13 AM
Complex Revit Drawings
Wed, Feb 2, 2011 at 5:55:23 PM
Page generation time: 1.5608
