14 Users Online (12 Members):
Forums >> General Discussion >> Revit Project Management >> Adjusting Line thickness for Sill
0 Posts No Rating |
Hi
I would like to know the best practice for printing lighter line weight for window sill.
there are work around for it. but is it possible that i can make an option and add to a view template.
please find the attached pic.
i want to get printed like in red mark. i have alot of windows in plan.
so manual work for each window takes alot of time
Something is wrong with the window on the right. The one on the leftg is typical Revit. The window on the right does not appear to be cutting the wall at the cut plane of the view. Maybe the window is too high.
0 Posts No Rating |
Yeah Done.
Thank u, it was set projection and cut wall line thickness in same thickness
adjusting text underline thickness? |
Fri, Sep 6, 2013 at 10:00:25 AM
Revit 2013 - Window frame sweep with wall thickness |
Wed, Nov 28, 2012 at 4:03:26 AM
window parameter to measure within frame..Please help~~ |
Tue, Oct 29, 2013 at 1:18:19 AM
Line thickness in detail family |
Wed, Jul 1, 2015 at 7:09:56 AM
Wall line thickness |
Mon, Sep 26, 2005 at 5:47:35 PM
