Forums >> Revit Building >> Technical Support >> Blocks
Tue, Aug 8, 2017 at 12:07:55 PM | Blocks
GLKIRK
Is there a way to make 2d blocks that can be saved somewhere and used over and over?
Thnks,
Gary
Revit 2013
Tue, Aug 8, 2017 at 2:05:32 PM | Blocks
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Make a family. Use symbolic lines in the family. load family into model. copy over and over. Dont draw drafting lines in model and combine them together in a group as every time you copy that group it will increase your model size.
Thu, Aug 10, 2017 at 1:05:44 AM | Blocks
tim123
4 Stars: 19 Votes
We have a seperate model which only contains 2D details.  When we need one we 'Insert from File' and bring the desired detail into our model.  Alternatively, for a 2D 'Block' or Family, use the standard 'Detail Item' family template as Beaucoupnice suggests.
dxf 3D imported blocks
Sat, Dec 6, 2003 at 11:06:06 PM
Help - How to create a Revit toposurface from AutoCAD blocks?
Thu, Aug 5, 2010 at 10:05:09 AM
blocks
Wed, Nov 3, 2010 at 4:23:56 PM
Modillion Blocks
Wed, Feb 17, 2010 at 12:45:14 PM
standard note blocks
Fri, Mar 7, 2008 at 10:22:22 AM
Page generation time: 0.4782
