14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Spot Elevation for a typical floor
Hello guys,
I have 2nd thru 4th floors that are typical. The sheet called "TYPICAL FLOOR" is associated with the 2nd floor and it has a spot elevation annotation on it. How to reflect on the same plan elevation spots of the rest of the floors?
Any best practices resolving this using Revit?
In AutoCAD I wrote in notes like this:
2nd floor EL.=10'-0"
3rd floor EL.=20'-0"
and so on.
Thank you!
You will have to use simple text here as well.
I had a similar question but I think that gave me the answer!
<ahref="http://www.windowtintingyuma.com/" target="_blank">residential window film service yuma az</a> |
Floor tag - elevation spot |
Thu, Apr 27, 2017 at 7:20:09 AM
Spot Elevation vs. Level elevation |
Tue, Aug 19, 2025 at 1:06:15 AM
Typical Floor as a Linked Revit File |
Fri, Aug 11, 2006 at 10:35:25 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
