18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> levels vs topo values
REVIT 2017 LT
See attached, see elevation view "2 Right". How to do I get the project geometry/level to move up to without changing the values of the topo points.
Seems like I have to be missing something simple. I've read help and treads regarding Project and Survey Base Points. And can get the levels showing correctly and I can move the topo down. But I can't do it without the values of the topo points changing and the points need to stay as they are.
Thanks,
JK
In your elevation view, move the level up.
You could also turn on the elevation of the level on the level marker and reset the elevation there.
like this?
sllana - I think so. What did you do?
WWHub - that would moving the level would work in this simple example but in a complex, nearly complete project that breaks too many connections and messes up too many views.
It doesn't mess with anything modeled or added to views. All sections, details etc will not be affected what so ever. The only thing that could be affected are any connections to site elements like sewer or water that are miss placed.
WWHUB - Maybe we are not talking about the same thing.
I can NOT move the levels up with the move command or by turning on the elevation of the level on the level marker and a new level in numerically. With either method I get about a dozen "can not be ignored" errors and must be canceled.
The simple file I posted was just an expample, the actual trouble making project is more complex and too large to post.
Was the level aligned to the topo point, still the height seem to look as 4feet..Correct me if its already solved.
Kalai Selvan.K
Senior Technician - ELV |
topo surface elevation value [ 1 2 ] |
Fri, Dec 15, 2017 at 4:15:36 PM
23
Modeling Topo After Building |
Fri, Jun 24, 2016 at 11:35:23 AM
problems with levels on topo surface |
Mon, Feb 22, 2010 at 12:11:48 PM
Creating Revit Topo from AutoCAD file |
Wed, Mar 7, 2018 at 8:30:50 AM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
