Forums >> Community >> Newbies >> DIMENSIONS HELP!
Wed, Jul 26, 2017 at 12:53:43 PM | DIMENSIONS HELP!
swooll3
1 Stars: 1 Votes
Hello,
I have an electrical panel and a whole bunch of conduits that I am trying to dimension. I know I can daisy chain all of the dimensions together, but can I pull one dimension from the end of the panel to center of the first conduit then continue that dimension all the way down to the next ones? So that they are all linked together but the dimension is pulling from the end of the panel. Or can I only daisy chain from conduit to conduit.
Wed, Jul 26, 2017 at 2:25:05 PM | DIMENSIONS HELP!
If you mean can all dimensions be from the panel to the conduit using only one starting point, then no.   The daisy chain is conduit to conduit.  Doing what you want will require seperate dimensions on top of each other.  (How do you expect the reader to understand this when they look like conduit to conduit?)
Wed, Jul 26, 2017 at 2:33:09 PM | DIMENSIONS HELP!
swooll3
1 Stars: 1 Votes
That is all I needed to know. Thanks for the reply
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 0.0733
