11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> visibility issue with view and view on sheet 2017
I am having some visibility issues with views and said views on sheets. an example is I have a view with a fill region that has transparency to it. it looks transparent in the view. once I place the view on the sheet it loses its transparency. anyone have this happen and if so what was the fix?
i had the same issue but with printing , i was applying transparency overrides on a few elements it looked good on screen but it was printed as opaque , the solution was setting transparency to 100% to print it right ,
on the other hands a problem between view and sheet is usually a bug , but if the sheets are printing as you want them , there is no harm
View Titles not aligning within sheet |
Sun, Nov 2, 2014 at 11:45:17 PM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
3D view visibility error |
Thu, Feb 26, 2009 at 4:40:37 AM
Sheet View Resolution Problem |
Sun, Apr 1, 2018 at 8:18:26 AM
View Schedule with Sheet Number & Detail Number |
Thu, Sep 1, 2016 at 12:07:37 AM
