Forums >> Revit Building >> Technical Support >> Telescoping pole family and chaning all 3 sections with adjustments issue....
Mon, Jul 17, 2017 at 7:56:23 PM | Telescoping pole family and chaning all 3 sections with adjustments issue....
EIhouse
Hello, I'm attempting and struggling to create a telescoping pole that has 3 sections: Lower/Mid/Top and I would like to set an overall height of the pole and then go in and adjust each of the 3 sections to different heights within the overall height.  If anyone knows how to accomplish this, and can assist, it would be Highly appreciated!Ive attached the file I'm working with.
Tue, Jul 18, 2017 at 7:31:37 AM | Telescoping pole family and chaning all 3 sections with adjustments issue....
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Your family must be 2018 version which I am unable to open yet. I created something based on your description though. Take a look to see how it was done.
You can parametrically control each pole length, each overlap length and each pole radius.The overall height is a function of the total of the arm lengths.
Tue, Jul 18, 2017 at 10:28:40 AM | Telescoping pole family and chaning all 3 sections with adjustments issue....
EIhouse
Thank you Beaucoupnice !!!    It was something simple, I was not locking reference planes to the extruded plole shape "-/   So when I moved the changed the lengths, it woudl only move the reference panes.
Again, Thank you for your help!
Revit MEP - How do I add a spare 2 pole breaker or 3 pole breaker
Wed, Oct 15, 2008 at 12:17:20 PM
Disfunctional Family
Fri, Aug 4, 2006 at 2:37:56 PM
3 Pole Panels?
Wed, Apr 11, 2012 at 2:57:16 PM
2 and 3 pole circuits in Revet MEP 2011
Thu, May 19, 2011 at 7:04:24 PM
Electrical Circuiting
Fri, Oct 19, 2012 at 6:23:41 PM
Page generation time: 1.9561
