Forums >> Community >> The Studio >> Copying Receptacle's
Thu, Jul 13, 2017 at 10:44:29 AM | Copying Receptacle's
swooll3
1 Stars: 1 Votes
Hello,
I have been trying to cut down on some time here in my office by copying all of my electrical boxes from room to room. When I copy though, I have to assign each one to a new face. Is there an option in the family that would allow me to place these boxes anywhere I would like?
Thanks
Thu, Jul 13, 2017 at 11:27:50 AM | Copying Receptacle's
Are you copying one at a time or multiple?
If one at a time, don't copy, just create similar.  That should allow you to place them.
Thu, Jul 13, 2017 at 11:35:45 AM | Copying Receptacle's
swooll3
1 Stars: 1 Votes
I have multiple families (electrical receptacle's) that I am trying to copy around. Most of the jobs will have a typical room. So I will do a mock up, then will duplicate that room throughout. And I can window over every box and copy and paste them, but then I can't move them into the right place in the room. I have to click each one and assign it to a new face.
Thu, Jul 13, 2017 at 11:44:52 AM | Copying Receptacle's
I don't like your process as I hear it.   If all of these are on the same wall, then create a group that is just these, not the wall.  Then you can place the group on your new wall.   BUT - If these items then need to be moved to a different spacing then even this is the wrong practice.  If each needs to be adjusted, then just create new and place in the correct place to begin with.
Thu, Jul 13, 2017 at 11:50:36 AM | Copying Receptacle's
swooll3
1 Stars: 1 Votes
I didn't think about creating a group. I will try that. I am fine placing a new box everytime. I just gets time consuming when there are hundreds of typical rooms. They don't need to be 100% accurate per the engineers model. I just need to make sure everything is in that room so that the guys on the field know what goes in the rooms.
Receptacle Tags
Mon, Jan 7, 2013 at 3:12:44 PM
Elevation of receptacle with formula
Wed, Nov 30, 2011 at 12:43:19 PM
Building Electrical Content
Thu, May 17, 2007 at 7:51:26 PM
Split Circuit Receptical Circuiting with Branch Duplex Recepticals
Tue, Mar 27, 2012 at 3:07:09 PM
Ceiling Mounted Receptacles
Mon, Mar 19, 2012 at 12:09:47 PM
Page generation time: 1.3194
