17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Central Model Has Been Restored
Hi Revit experts;
We are using Revit 2017.2; file-based worksharing.
The central model overrides by itself - it restores a two-month old copy instead the current file. It happened with different projects, different users.
We know how to create a new central from a local copy. We don't know WHY IT HAPPENS.
Please help.
My first response "...overrides by itself..." <<< is that I doubt this very much. Without any other knowledge given, I suggest that you re-examine the process of all of your users.
You haven't told us how many users, their knowledge level, how long you have been using Revit. This would be a good start.
4 users; Revit training and from 3 to 10 years experience.
Sit down with your staff .... someone is over-writing the central.
Thanks.
But it happened several times with different projects. Plus the same happens with AutoCAd files.
If it crosses programs, then it must be a system level problem .... or still a staff issue. It is for sure not a program issue.
Thank you. I came to the same conclusion.
Converting Central Model to Basic Model |
Wed, Jul 2, 2014 at 11:48:21 AM
Central Model Update issue MEP2013 |
Mon, Nov 12, 2012 at 9:09:32 AM
Detaching from Central Model...I CANT! |
Fri, Aug 27, 2010 at 10:26:55 AM
Central Model Lock Advice |
Wed, Oct 23, 2013 at 10:40:21 AM
Working over WAN central model |
Sun, Aug 26, 2012 at 9:59:26 PM
