Forums >> Revit Building >> Technical Support >> New poster- Raised panel
Mon, Jul 10, 2017 at 6:09:58 PM | New poster- Raised panel
ccrocco
Hi Everyone
I am just starting to get the hang of revit, still ALOT more to learn but I am trying to model this exterior wall paneling for a building. See attached and let me know if you have any tips.
Chris
Tue, Jul 11, 2017 at 12:55:34 AM | New poster- Raised panel
tim123
4 Stars: 19 Votes
Start by creating the windows using curtain walling.  You will need to create the two different panel types. The solid panels can be created as one type of panel - they should flex to the curtain grids.  The profiles on the walls and the coping can be hosted wall sweeps or in place  sweeps.  The railing can be created by creating custom balusters for a railing.  The block pattern can be created by modifying the .pat file, or using a third party hatch creating application.
Tue, Jul 11, 2017 at 6:17:00 AM | New poster- Raised panel
ccrocco
Tim thank you for all the information but I am asking specifically on how to create the raised paneling under the windows and in between the windows.
Tue, Jul 11, 2017 at 6:38:04 AM | New poster- Raised panel
tim123
4 Stars: 19 Votes
Create those panels as a curtain wall panel family - they should flex to the curtain grids that you set up (therefore only one required).
Painted Raised panel shutters
Sat, Jul 22, 2017 at 9:18:15 AM
Raised floor system
Thu, Jun 25, 2015 at 2:10:09 AM
i need help with wainscoting
Wed, Sep 10, 2014 at 1:45:14 PM
Creating Raised Floor systems
Thu, Nov 13, 2008 at 11:49:31 AM
Curved sweep?
Thu, Mar 11, 2010 at 3:31:16 PM
Page generation time: 5.7179
