Forums >> Revit Building >> Technical Support >> lighitng fixtures on ceilings and view range
Mon, Jul 10, 2017 at 11:08:03 AM | lighitng fixtures on ceilings and view range
sjain1207
1 Stars: 1 Votes
I am working on a project in revit which requires lighting to be added into the model. i was able to load the lighting families into revit but when i start placing the lighting it places the lighting onto the floor even though i am in the ceiling plan. Could it be because of wrong view range, if so could anyone guide me through it.
Mon, Jul 10, 2017 at 3:43:02 PM | lighitng fixtures on ceilings and view range
Alot of newbies don't understand that a ceiling plan  in Revit is NOT a copy of the floor plan and called a ceiling plan.   So did you actually create a Reflected ceiling plan from the Revit view dropdown?
IYou really should not see your floor in this view.  Most people only have their range set deep enough to just catch the door .... if that.
Mon, Jul 10, 2017 at 3:59:45 PM | lighitng fixtures on ceilings and view range
sjain1207
1 Stars: 1 Votes
no the RCP has been already loaded by a 3rd party and is already there even in the model. Still cant fix the luminaire onto the ceiling.
Mon, Jul 10, 2017 at 4:13:58 PM | lighitng fixtures on ceilings and view range
OK.... Under properties, in the view, does it say ceiling plan?  NOT the view name.
Is the ceiling in your model or is it in a linked model?
Has some one changed the work plane setting in the view?
Are you sure your lights will host to a ceiling?
view range in RCP
Thu, Apr 29, 2004 at 8:11:22 AM
Ceilings not appearing
Wed, Nov 4, 2015 at 4:48:40 PM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
Lighting fixtures at different heights
Wed, Jul 15, 2015 at 11:17:29 AM
view range for floorplan views
Tue, Sep 27, 2005 at 2:41:03 PM
Page generation time: 2.7255
