Forums >> Revit Building >> Technical Support >> Sweep not Moving with door family
Fri, Jul 7, 2017 at 5:36:52 AM | Sweep not Moving with door family
Kroyan
Hi Guys,
Struggling a bit here with modifying a standard double glass door's handles. I've managed to place the extrusions where they need to be but once loaded into the project the handles don't adjust along with the rest of the door elements to suit the opening size.
I've tried to lock them to reference planes to no avail. Would appreciate any help! I've attached the file (2016) so you can have a look. Thanks.
Fri, Jul 7, 2017 at 9:04:45 AM | Sweep not Moving with door family
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Make your handle as a separate family (generic model face based) and nest it to your door family. It would be much easier to control it that way.
Fri, Jul 7, 2017 at 10:26:48 AM | Sweep not Moving with door family
And you can use it in other families!
Mon, Jul 10, 2017 at 3:25:31 AM | Sweep not Moving with door family
Kroyan
Worked a treat thanks guys!!
Door Panels
Mon, Jun 17, 2013 at 5:01:49 PM
Help,what's wrong with my door family
Thu, Dec 30, 2010 at 8:06:56 AM
Edit/Add trim to Door Family
Thu, Jan 14, 2016 at 10:02:29 AM
Profiles, sweeps, and door frames...
Tue, Mar 3, 2009 at 7:03:51 AM
how to make door frames cut wall sweep? [ 1 2 ]
Mon, Jun 9, 2008 at 8:11:27 AM
20
Page generation time: 0.9448
