Forums >> Revit Structure >> Technical Support >> Cutting wall end with in-place void - Revit 2018
Wed, Jul 5, 2017 at 3:06:19 PM | Cutting wall end with in-place void - Revit 2018
edu5436
Hi, I can't cut a wall end to a certain angle using a void extrusion, in Revit 2018. I've tried in a new project, empty, just a wall from level 1 to 2, and an inplace family void extruded in the end of the wall as a 45 degree triangle. The error message says "Some Void Forms of this family do not cut anything and will be deleted. To make a Void Form cut something else use the Cut Geometry tool." I've tried making the void larger than the wall, smaller, longer, shorter... Always the same message. Thanks.
Wed, Jul 5, 2017 at 7:52:41 PM | Cutting wall end with in-place void - Revit 2018
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
'To make a Void Form cut something else use the Cut Geometry tool' - do what the error message says before you exit void sketch mode.
Thu, Jul 6, 2017 at 3:28:05 AM | Cutting wall end with in-place void - Revit 2018
edu5436
The message pops when I try to finish the void make with the "OK" green mark.
Thu, Jul 6, 2017 at 6:11:41 AM | Cutting wall end with in-place void - Revit 2018
First, the void actually has to intersect the solid, then do what pijpiwo writes.
Thu, Jul 6, 2017 at 12:56:55 PM | Cutting wall end with in-place void - Revit 2018
edu5436
The void intersects the wall, I can see in the 3d view. I follow Autodesk video step by step but when is time to finish, I get the error message... Is it a bug or am I missing something?
Thu, Jul 6, 2017 at 2:05:27 PM | Cutting wall end with in-place void - Revit 2018
Reread what pijpiwo wrote ...." before you exit void sketch mode."
Thu, Jul 6, 2017 at 5:08:30 PM | Cutting wall end with in-place void - Revit 2018
edu5436
Yeaaahhh! Thanks a lot!
V. 2018 - cutting wall sweeps with void forms for stadium seating
Thu, Jan 11, 2018 at 12:50:20 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:58:59 PM
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Wall void
Wed, Jul 25, 2018 at 10:37:10 AM
Page generation time: 1.9060
