Forums >> Revit Building >> Technical Support >> Extruded roof - fascia - (Newbie question)
Tue, Jul 4, 2017 at 3:23:53 PM | Extruded roof - fascia - (Newbie question)
hoyt
I have created an extruded roof in Revit 18.  CryingSee attached file.)  However, when I attempt to add a fascia, Revit does not allow me to select the edges of the roof.
If fascias are not allowed on such roofs, how does one assign a finish material, such as stucco to the sides of the roof?  Similar question for assigning a mateirals to the top/bottom of the roof.
Thank you in advance.
Hoyt (a Revit newbie)
Wed, Jul 5, 2017 at 3:29:45 AM | Extruded roof - fascia - (Newbie question)
tim123
4 Stars: 19 Votes
It shouldn't be a problem to attach fascias to extruded roofs.  I don't see your attachment, so I'm not sure what you're trying to do, but I attach an image with two wxtruded roofs with fascias.
Wed, Jul 5, 2017 at 7:30:04 AM | Extruded roof - fascia - (Newbie question)
hoyt
Thank you very much for your response.  I am very glad to learn that fascias are available.  I have attached a file with the extruded roof.
Hoyt
Wed, Jul 5, 2017 at 9:25:31 AM | Extruded roof - fascia - (Newbie question)
tim123
4 Stars: 19 Votes
Rather attach an image showing you problem.  What you have attached is an IFC file and we can't do much with that.  However, I can view your roof, and I dont think that you should have a problem attaching fascias.  In this case, I think that you should have used standard roofs for what you have shown, as these are much more controllable.
Wed, Jul 5, 2017 at 9:38:33 AM | Extruded roof - fascia - (Newbie question)
hoyt
Tim,
I have attacehd a screenshot of the roof.  The exact issue that I am having is that when I attempt to select a plane of the roof, by selecting the upper edge of a roof plane, to add a fascia, the entire roof is selected.
The screenshot was taken just after I selected an upper edge.  As can be seen in the screenshot, the entire roof is selected.  Thus, no fascias are added.
Hoyt
Wed, Jul 5, 2017 at 9:42:14 AM | Extruded roof - fascia - (Newbie question)
hoyt
Tim,
A link to the Revit file follows:  https://www.yousendit.com/download/dDZHNWNzR3N3TGhFQmNUQw
The file is 3MB in size, which is too large to upload to the forum.
Hoyt
Wed, Jul 5, 2017 at 9:47:26 AM | Extruded roof - fascia - (Newbie question)
When your file is too big, you can always copy your elements to a new file and upload that.
Wed, Jul 5, 2017 at 12:17:50 PM | Extruded roof - fascia - (Newbie question)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Technically, your roof is not a roof. It’s just an in-place extrusion under the roof category - fascia tool will not work here. Use actual roof tool and create your roof by extrusion or by footprint with a negative slope.
Wed, Jul 5, 2017 at 4:27:26 PM | Extruded roof - fascia - (Newbie question)
hoyt
Thank you very much.  I will rebuild the roof using the roof tool.
Hoyt
Wed, Jul 5, 2017 at 5:23:12 PM | Extruded roof - fascia - (Newbie question)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Hoyt, I just noticed something about your roof. Do you want the edges of your roof to be perpendicular to the roof plane (as you have it), or cut plumb?
Edited on: Wed, Jul 5, 2017 at 5:23:33 PM
Wed, Jul 5, 2017 at 5:39:44 PM | Extruded roof - fascia - (Newbie question)
#11
hoyt
I want the roof edges to be perpindicular to the roof plane (not plumb).  That is why I did not use the standard method of constructing the roof.
Hoyt
Wed, Jul 5, 2017 at 7:09:17 PM | Extruded roof - fascia - (Newbie question)
#12
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Two options:
1. Use what you have - in-place extrusion. Copy to clipboard -> paste to the same place (two roofs in the same place) -> edit one extrusion and make it larger (or smaller) by the thickness of the fascia and adjust the height of it as well -> finish extrusion (green check mark) -> use join or cut geometry tool to remove the inside volume of the ‘fascia’ roof.
2. use roof tool -> cut the edges with in-place void so they are perpendicular to the roof plane -> use fascia tool.
I’d use option 2.
EDIT: File attached
Edited on: Wed, Jul 5, 2017 at 7:22:47 PM
Wed, Jul 5, 2017 at 7:25:52 PM | Extruded roof - fascia - (Newbie question)
#13
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
File attached - I had to reduce its size.
Wed, Jul 5, 2017 at 8:12:43 PM | Extruded roof - fascia - (Newbie question)
#14
hoyt
Hoyt
Fascia Board Too Long
Tue, Nov 20, 2012 at 10:19:31 AM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
Extruded roof - surface pattern displaying incorrect
Wed, Sep 8, 2010 at 10:00:11 AM
HOW DO I ADD NEW FASCIA?
Tue, Mar 13, 2007 at 3:58:46 PM
Page generation time: 1.6503
