Forums >> Revit Building >> Technical Support >> base trim
Wed, May 24, 2006 at 2:36:18 PM | base trim
arch00
Could anyone recommend which command I should use to create a tile base trim. Thanks Gar
Wed, May 24, 2006 at 9:00:46 PM | RE: base trim
hisdirt
5 Stars: 5 Votes
... tile base trim? If you could elabourate on what that is, perhaps post an image on the kind you're after? (sorry, terminology is a little different where Im from...) haha, but whatever it is I'll probably suggest an in-place family
Thu, May 25, 2006 at 8:19:59 AM | RE: base trim
arch00
A trim which is added on the bottom of a wall. It is like crown moulding for the floor. Gar
Thu, May 25, 2006 at 11:18:54 AM | RE: base trim
lpromana
4 Stars: 2 Votes
If you are on Revit 9 there is a new family called 3D 2pick Family that will let you do that, it is a "generic model line based" if you need more info I will be more than happy to help you
Thu, May 25, 2006 at 12:26:13 PM | RE: base trim
arch00
I am using revit 8.1 Gar
Thu, May 25, 2006 at 5:09:28 PM | RE: base trim
arccodex1
3 Stars: 1 Votes
Load your own Profile.rft family then Modelling... Host Sweep... Wall Sweep Properties... Edit/New... and select your profile family Or if you want the Sweep to reside on all of the walls then Select the wall... Properties... Edit/New... Edit Structure Preview in Section View... Sweeps... and Load your Profile.rft family It's not unlike the reveals you asked about earlier.
Thu, May 25, 2006 at 5:12:12 PM | RE: base trim
hisdirt
5 Stars: 5 Votes
Skirtings? There are a couple of ways to make them, like you can use the wall modifier to host a sweep, but this way runs into problems real quick (skirtings dont go through walls etc.) It does depend on how you like to work, but the best way we are finding is using in-place families. The learning curve is a little steeper but once you get the hang of it you can do a big house in under 10 mins. Draw your profile as a family and load it into the drawing (you could draw a couple of different profiles and have options). Then just draw sweeps (reference plane as the floor level) and specify the profile you want. There are alot of resons why in-place families work very well; you can turn the visibility of the skirtings off in plan views, you can set the material and profile up to be parameters so changing the skirtings through the whole house is as simple as editing a family parameter... Hope this helps, if you arent talking about skirting boards Im sure it will apply anyway! Post edited on 2006-05-25 18:00:45
Fri, May 26, 2006 at 10:21:55 AM | RE: base trim
arch00
Thanks, Guys I guess it's the same as the reveal question I had on my other post. Gar
Fri, Jul 25, 2008 at 9:48:03 AM | base trim
diggyblue
I have base trim on my walls, but I do not want it to show up in plan.  How can I turn this off?
Thanks,
Megan
Fri, Jul 25, 2008 at 10:20:45 AM | diggyblue
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting diggyblue from 2008-07-25 09:48:03
Thanks,
Megan
this should provide you some info on the subject
http://www.revitcity.com/forums.php?action=viewthread&thread_id=7003
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Base trim in plan
Fri, Jul 25, 2008 at 10:14:58 AM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
door trim stops short of floor
Wed, Jul 24, 2013 at 3:24:32 PM
Trim Roof Facia
Sun, Jul 3, 2016 at 12:18:25 PM
wood trim in revit arch 2009
Thu, Jul 31, 2008 at 4:53:32 PM
Page generation time: 0.0851
