Forums >> Community >> Newbies >> Cannot see walls above current level
Tue, Jul 4, 2017 at 7:32:46 AM | Cannot see walls above current level
oxygenp
Hey guys,
I'm currently switching from AutoCAD to Revit and have an issue: cannot see the walls from an above level, even if my view range is set this way. My view range only shows me cuts through some sunshade components - see attached screenshots. Why is this happening? Why can't I see the walls from above levels.
Thanks
Tue, Jul 4, 2017 at 8:22:35 AM | Cannot see walls above current level
Do you have a floor?......
Try to learn Revit techniques.  In this case, don't set your view dept any deeper than your level.  Then use the underlay setting to include the floor below.
Tue, Jul 4, 2017 at 8:34:48 AM | Cannot see walls above current level
oxygenp
Of course I have a floor.
Tue, Jul 4, 2017 at 8:39:39 AM | Cannot see walls above current level
Sorry - at first I thought the walls below but I see now you want those above..... Again - use an underlay.
Tue, Jul 4, 2017 at 8:56:00 AM | Cannot see walls above current level
oxygenp
Tried that but again, I can see all elements except the walls. So frustrating.
Tue, Jul 4, 2017 at 9:04:20 AM | Cannot see walls above current level
Read this.
Changing display of walls below current level.
Wed, Jun 18, 2014 at 7:36:35 AM
Current Level
Fri, Jan 12, 2007 at 6:03:00 PM
Spot elevation and "current level"
Fri, Feb 17, 2017 at 3:11:01 AM
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Level for current view only?
Tue, Oct 6, 2015 at 7:43:54 AM
Page generation time: 0.4451
