13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> elevation extents
been a while since i posted, but i have an issue and this is where i turn when i am stumped...anyone have issues while placing an interior elevation and when you go to the view it is 2" high and you need to adjust the crop region manually. i can use the elevation marker and place it outside the building and it works fine, the view shows the whole elevation. i am getting frustrated with having to adjust each elevation.
thaks in advance for any ideas.
revit 2017.2
In all my years of Revit, I never did find out how these got reset from the default. Maybe someone learned how at AU.
I found this, hope works 4 u:
Change the settings (physically) for the crop region in the template file you are using.
Open template draw a wall
open elevation change the crop region
delete the wall
open splash screen
close hidden windows
save
close
Jimi Clarke
I know that the template is not the issue. This setting somehow gets altered during use in a file that came from a correct template.
Can I set default interior elevation view extents? |
Thu, May 29, 2014 at 8:10:08 AM
Elevation Extents |
Thu, Mar 5, 2015 at 6:56:31 PM
3D level Extents |
Mon, Nov 2, 2009 at 4:02:58 PM
Aligning grids the same in each level? |
Fri, Sep 23, 2005 at 11:13:39 PM
Elevation Line Extensions |
Mon, Apr 30, 2012 at 8:08:08 AM
