Forums >> Revit Building >> Technical Support >> Where should I create sheets? (Linked Revit)
Tue, Jun 27, 2017 at 4:31:01 PM | Where should I create sheets? (Linked Revit)
sepidehazargoon2
I’m working on a project containing 9 Buildings (5 types) with a 5Hactars sloped lot. I broke down the file to 6 different linked file after it began to get really heavy especially with a complicated topography. Now, I have a Topography file and 5 type building linked to a MAIN file.
Now I’m trying to create sheets, laying out each building design. The problem is if I create the sheets on the main file, I cannot edit linked file easily and the annotations looks messy (I’M NOT SURE WHY?). On the other hand, if I create the sheets inside each file, I don’t see the topography which is important to see especially in 3d camera views. Pleas recommend the best way to create my sheets.
Thanks
Wed, Jun 28, 2017 at 1:02:33 AM | Where should I create sheets? (Linked Revit)
tim123
4 Stars: 19 Votes
I would create the sheets from the individual models and link the topography into these models.  It is easier to track sheets if they are created in eash model.  Use a suffix in the drawing name or number so that it can easily be seen from which model the drawing originates.
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:28 PM
sheet index order with Linked models
Sun, Mar 13, 2016 at 12:37:27 PM
plotting sheets from a linked model
Thu, Oct 16, 2014 at 11:11:01 AM
Reloading Linked Files - Lost Sheet Views
Tue, Aug 23, 2011 at 8:52:01 AM
Base building model, fitout model and sheets
Wed, Jun 5, 2013 at 5:42:52 PM
Page generation time: 2.6201
