Forums >> Revit Building >> Technical Support >> Embedded material
Tue, Jun 27, 2017 at 7:47:15 AM | Embedded material
suzypasko
Hi, I have a door family which shows up with white glass. All other glass is blue. I checked the door, material glass is blue. Checked the embedded door leaf: material glass is blue.And the glass is 'Glass'material in every instance.  Any suggestions?
Thanks, Suzanne
Tue, Jun 27, 2017 at 8:10:16 AM | Embedded material
How did you check?  Settings within the family are controlled by the project after their initial load.
Users can paint most elements independent of settings.
embedded detail
Wed, Jan 25, 2012 at 3:29:35 PM
Can you use type catalogs when the type is an embedded file?
Thu, Mar 5, 2009 at 1:46:09 PM
BM TO BM EMBEDDED IN WALL
Tue, Jan 8, 2008 at 9:49:44 AM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Scheduling Embedded Curtain Wall Doors
Thu, Jul 31, 2008 at 11:35:19 AM
Page generation time: 0.6872
