15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Extrusion won't cut
0 Posts No Rating |
Hi,
Im working on a complex roof made with different families using blends and voids. After making 3 of these that work fine, the one in the picture won't cut anymore. Can anyone tell me what it is judging by the picture?
Not sure what we are seeing. Why not use a conventional roof? If you are having trouble using a standard roof, we can help if you describe what you want.
0 Posts No Rating |
My teacher did it this way so the only way i know how to make a roof under an angle is by creating families... To make my images more clear, it is a generic model blend with a blend void to get the thickness of the roof. My problem is the void doesn't cut while it did with my other forms (I made three of these with different parameters). I was hoping someone could describe the most common procedures when a void isn't working to be honest.
Your problem could be resolved much quicker if you could upload your file.
You wrote "My teacher did it this way so the only way i know how to make a roof under an angle is by creating families.."
This is a great post that may solve part of your needs.
https://www.revitcity.com/forums.php?action=viewthread&thread_id=35345
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
Void Sweep won't cut extrusion |
Fri, Aug 24, 2012 at 3:02:42 PM
"Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion. |
Mon, Jun 5, 2017 at 10:57:14 AM
re-joining (?) cut extrusion with extrusion |
Tue, Apr 17, 2007 at 10:26:27 PM
Doors won't cut |
Mon, Feb 15, 2016 at 11:25:43 AM
