Forums >> Revit Building >> Technical Support >> Can't select model lines
Wed, Jun 14, 2017 at 9:29:56 AM | Can't select model lines
Junsvier
Hi! I'm struggling with a very mysterious issue. I have a wall with an aluminium finish, and I drew some model lines on its face to show the panels rythm of the facade. Right now I need to change the position of this panels, and I cannot select this model lines (***??). When I try to select them, it says they are part of the wall they were drawn on (weeeiiird). Any lights on this mysterious cannotselectlines issue?
Edited on: Wed, Jun 14, 2017 at 9:37:45 AM
Wed, Jun 14, 2017 at 9:39:10 AM | Can't select model lines
Junsvier
problem solved, sorry for the inconvenience Smile
Wed, Jun 14, 2017 at 9:40:42 AM | Can't select model lines
I don't think that is a model line.  What was your process to place this?
Wed, Jun 14, 2017 at 10:33:16 AM | Can't select model lines
Junsvier
It was just a lapse of concentration. The thing is that I recall drawing the lines as model lines some time ago, so I kept trying to select and delete them, but revit didn't allow me to do so. Which is logic, because they were just lines from a surface pattern I created for the aluminium material (fail!) Now everything is cool. Thanks for the answer anyway!
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Can't select the linked model
Mon, Aug 4, 2014 at 1:06:26 PM
Received revit model from client and can't select certain walls
Mon, Apr 4, 2016 at 3:49:04 AM
Can't select model items by clicking
Wed, Sep 30, 2009 at 12:52:50 PM
Can't select gridlines
Fri, Oct 3, 2014 at 10:00:46 AM
Page generation time: 0.8753
