Forums >> Revit Building >> Technical Support >> Window in brick/stud wall
Wed, May 24, 2006 at 10:15:02 AM | Window in brick/stud wall
cubman
I need to find a window that would go into a stud/brick wall 9-1/2" thick with brick sill and soldier above. I am not sure on how to go about it. I have only put windows in stud walls before. I also need to do this for my garage doors as well. Should I put in a window with no trim and and make the sill and soldier around it? I am also using 7.1 for this project. I did not move up to 9 since I am almost finished with it. Thanks for your comments
Fri, May 26, 2006 at 2:43:48 AM | RE: Window in brick/stud wall
fazerneil
4 Stars: 5 Votes
yOU CAN EITHER CREATE A FAMILY, USING ONE OF THE EXISTING CILL OR LINTOL FAMILIES AND EDIT. OR CREATE A FAMILY WITHIN THE PROJECT BY DRAWING THE CILLS ON ELEVATION AND GIVING A DEPTH, THEN APPLYING A BRICK SOLDIER MATERIAL. (APOLOGIES FOR CAPS BEING ON LOL)
Window Placement in Stud/Brick Veneer Wall [ 1 2 ]
Wed, Feb 4, 2009 at 11:22:19 AM
15
RAC 2012: Window Trim Reveal in brick/Stud Wall
Mon, Jul 2, 2012 at 2:08:10 PM
Question: Window Placement?
Fri, Sep 8, 2006 at 12:33:07 PM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
stud wall w brick
Fri, Mar 19, 2010 at 8:45:51 AM
Page generation time: 3.1037
