Forums >> Revit Building >> Technical Support >> Importing walls into an Rfa file
Tue, Jun 13, 2017 at 3:25:22 AM | Importing walls into an Rfa file
marcusqwj
Hello, I'm keen on creating rooms as a family type to test certain layouts, in which the length and width can be parametrically controlled.
I understand that Revit families can be nested. I've manage to import doors but not walls into my Generic Model Floor template. Is there a way to get the walls into an Rfa file? If it is not possible, are there possible workarounds? Thank you very much .
Tue, Jun 13, 2017 at 6:12:03 AM | Importing walls into an Rfa file
System families can not be added to other families.  So no walls, fllors, roofs, column lines, etc ......
Need to convert RVT file to RFA
Sat, May 22, 2021 at 6:14:06 PM
Problems when importing Architects Revit File
Fri, Feb 6, 2009 at 12:47:49 PM
Converting Room Areas to Walls and Importing ADT lines into Walls
Mon, Sep 15, 2008 at 12:44:51 PM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
How to get a photo into a .rfa-file???
Tue, Jun 29, 2004 at 11:50:30 PM
Page generation time: 3.4434
