Forums >> Revit Building >> Technical Support >> Locate a family
Fri, Jun 9, 2017 at 8:24:10 AM | Locate a family
paudy86
Hi,I have an issue where we are trying to export a CAD file from Revit to coordinate with another consultant. However when we do, the CAD files are huge (80mb+). After some investigating I've discovered that the problem goes away when I turn off "Imports in Families", specifically the item "(Default)". Is there a way to find which family/families contain "(Default)". We have a lot of families in our model both standard and custom as well as those received from manufacturers etc.Thanks in advance,P
Fri, Jun 9, 2017 at 10:13:42 AM | Locate a family
archigrafix
5 Stars: 4 Votes
You can for instance override the graphics the layer Default to another color and see in the model or views. Thats the graphic solution to the problem.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
"re-use/re-locate" feature
Tue, Feb 1, 2005 at 3:47:19 PM
Locate instances of family, also Hello!
Tue, May 19, 2015 at 12:34:54 PM
Locate a Linked File in a project
Wed, Sep 23, 2015 at 3:24:29 AM
trying to locate a door tag tutorial
Wed, Jul 23, 2008 at 12:57:08 PM
Family Editor
Wed, Jan 5, 2011 at 4:36:29 PM
Page generation time: 0.6205
