Forums >> Revit Building >> Technical Support >> is it possible to disable phasing Graphic Override on a view
Thu, Jun 8, 2017 at 1:55:17 PM | is it possible to disable phasing Graphic Override on a view
sepidehazargoon2
I'm using Revit 2017 and trying to Render an interior view. Some of the walls are existing with new finish. Unfortunatley, with the phases Graphic Override, all the existing walls are showing gray, so I was wondering if there is a way to dissable that in one or two views.
Thanks
Thu, Jun 8, 2017 at 3:34:46 PM | is it possible to disable phasing Graphic Override on a view
Change the phase setting of the view to show complete.
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Override Phase Filter for Specific View only
Fri, Nov 4, 2016 at 9:45:40 AM
Phasing moved to Visibilty/Graphic
Wed, Nov 18, 2009 at 4:11:56 PM
sheet graphic override
Thu, Dec 16, 2010 at 11:03:16 AM
Dual Phase Graphic Override?
Tue, Apr 28, 2009 at 9:23:26 AM
Page generation time: 0.8469
