Forums >> Revit Building >> Technical Support >> Show dimensions of the underlay
Wed, Jun 7, 2017 at 7:30:24 PM | Show dimensions of the underlay
barryco
Hi. I'm using revit 2016.
Is it possible to show the dimensions when turning on the underlay on plans?
For example, I'm in second floor plan, i turned on the ground floor underlay but the dimesions from that plan is not showing. I need it to align my dimensions. Thanks!
Thu, Jun 8, 2017 at 3:27:31 AM | Show dimensions of the underlay
archigrafix
5 Stars: 4 Votes
Maybe because the annotations are just for that view. You can perhaps make a DWG of that plan (tha includes the dimensions) and link it instead of underlay.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Jun 8, 2017 at 7:52:18 AM | Show dimensions of the underlay
If the dimensions are to something that spans both plans like column lines or exterior walls, simply copy form one plan and paste to the next.  (For column dimesions you can copy apaste to multiple views and do them all with just a couple of clicks.)
Underlay won't show up??
Mon, Aug 29, 2016 at 11:39:28 PM
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
dimensions
Wed, Apr 25, 2007 at 5:27:51 PM
My walls do not appear in an underlay on my roof plan.
Fri, May 29, 2009 at 7:27:34 AM
Page generation time: 0.4610
