Forums >> Community >> Newbies >> Object Style not showing unless object highlighted
Wed, Jun 7, 2017 at 7:02:19 PM | Object Style not showing unless object highlighted
bitslap
I have an planting subcategory 'to remove' in object styles which uses a dashed line.  It has been working fine but I have messed something up.
At this stage, the line looks like a default style, but when I hover over the object, the blue selection highlight shows line correctly dashed.
Is there a visibility setting or something that I need to reset?
Thanks.
Wed, Jun 7, 2017 at 8:12:52 PM | Object Style not showing unless object highlighted
bitslap
The problem was that I had moved the trees to another phase (demo) that was changing the line style.
Thu, Jun 8, 2017 at 3:29:24 AM | Object Style not showing unless object highlighted
archigrafix
5 Stars: 4 Votes
Many possibilities in Revit...
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Detail Component Object Style?
Fri, Apr 9, 2010 at 10:01:48 AM
OBJECT STYLE ISSUE
Fri, Jan 30, 2015 at 10:34:36 AM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Wall Sweep Object Style?
Wed, Jul 18, 2007 at 11:36:49 AM
Object Styles
Thu, Oct 4, 2007 at 10:42:57 AM
Page generation time: 0.4118
