Forums >> Revit Structure >> Technical Support >> Formula with YES/NO Parameters
Tue, Jun 6, 2017 at 1:08:21 PM | Formula with YES/NO Parameters
TeamNga
1 Stars: 1 Votes
Hello.
I have 5 YES/NO instance parameters in a family that I want to be able to check only one at a time. So I need to have all five available for checking but when I check one the other four become uncheckable. (Greyed out). I tried playing around with and, or, if, not in the formulas but cant seem to get what I want because as soon as I type in a formula the parameters gets grey out.
Does anyone know if this can be achieved and how?
Thanks you.
Tue, Jun 6, 2017 at 1:58:42 PM | Formula with YES/NO Parameters
CDWdavid
5 Stars: 5 Votes
Please check the post below to see if that was what you are looking for.
https://www.revitcity.com/downloads.php?action=view&object_id=11536.
The way I did was using Yes/No parameters to control if the extrusion is visible or not and associated with other parameters to control the graphic of the family.
You can open any door family, go to “Properties”, under Graphic, Type A, B, C, D are all Yes/No parameters, then combine with “IF” formula. This way you can have more combinations than just Yes/No which has two only.
Controlling Yes/No Parameters with Formula
Thu, May 29, 2008 at 7:53:19 AM
Enter formula anywhere a number is required
Tue, May 8, 2012 at 10:57:12 AM
basic formula question regarding parameter use
Wed, Jun 16, 2010 at 5:34:23 PM
Revit 2010 family parameters formula and room tag
Fri, Aug 7, 2009 at 4:28:34 PM
conditional formatting yes no parameters
Tue, Oct 28, 2008 at 9:58:54 AM
Page generation time: 4.0562
