19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Spell Check Entire Project
105 Posts No Rating |
2017 OS10,
There is a find a replace for the entire project. Is there a spell check for the entire project? If not - any idea why it can obviously search the entire project.
You should be able to write a dynamo script for this.
Of course either the program would somehow have to have you interact to change the spelling or the better solution would be to write out a list of what and where they are.
Edited on: Mon, Jun 5, 2017 at 10:20:44 AM
I have found an easier way to spell check a whole project (or most of it anyway)
- Go to any view that has a text note.
- Select the text note and right click it.
- Choose "Select All Instances..."
- Then choose "In entire Project..."
- Then Fn-F7 to spell check
You could make a dummy view that has every text type you used in the project included and then choose them all and then do the commands above and it will spell check them all. It is still not checking schedules, tag, labels, etc. but it does do most of a project.
Neat trick - I will have to try it.
Spell Check and Text Format |
Thu, May 22, 2008 at 7:11:35 PM
spell check |
Mon, May 22, 2006 at 1:22:57 PM
Spell Check of sheet & view Names |
Wed, Mar 5, 2008 at 10:01:45 AM
Spell Check stopped Working |
Mon, Oct 5, 2015 at 6:38:39 PM
Spell Checking in Note Blocks |
Wed, Dec 20, 2006 at 7:13:54 AM
