12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Stringer short at top and bottom
How do I adjust the stringer to reach the top riser and extend past the bottom nose? See picture attached.
I drew the stairs with the run layout and automatic middle landing.
I was able to make some modifications if I edited the stair then the stringer but these are not type changes. I suppose I can edit the sketch but I was hoping to avoid that.
If you hover your mouse over the stringer and hit tab once, you can select it separately from the stair itself. You then have further constraint options to adjust it. With it selected and clicking edit in propoerties you have further options about its size. Alternatively, if you hover your mouse over the stair treads, you can select them and choose in properties to end with a riser ( or not). Try these two options, they may help.
Stringer Haunch (level off) at top of flight |
Wed, Dec 14, 2011 at 2:03:06 PM
How to create a double landing stair (one top and btm) |
Tue, Nov 1, 2011 at 7:47:28 AM
Need Help on Stringer |
Fri, Jul 10, 2015 at 7:24:07 AM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
Stringer |
Mon, Jul 21, 2008 at 12:41:10 AM
