Forums >> Revit Building >> Technical Support >> Using topography to cut an object
Wed, May 31, 2017 at 1:49:22 PM | Using topography to cut an object
amploghoft
I have a project where I am fabricating large boulders. I have a topography surface, and know that footings for the fabricated boulders must be located approximately 2' below grade. How can I use a topo surface to cut the boulders I have designed so that I may find out the volume of concrete I need? This is also a crucial step in my construction drawings. I designed the boulders in AutoCAD and imported them to Revit, where I did the rest of the work, so a solution in either software is very welcome.
Thu, Jun 1, 2017 at 6:52:01 AM | Using topography to cut an object
Topo will not cut anything.
Visibilty of cut topography in section views
Sun, May 3, 2009 at 2:55:28 AM
Extend topography.
Mon, Mar 26, 2007 at 8:21:29 PM
Cut graphics for topography
Tue, Jun 12, 2012 at 1:27:06 PM
Topography Cut/Fill Schedule
Thu, Nov 16, 2006 at 11:15:51 AM
splitting topography
Wed, Jan 19, 2005 at 8:36:37 PM
Page generation time: 0.6512
