Forums >> Revit Building >> Technical Support >> Properties Palette
Tue, May 30, 2017 at 2:49:23 PM | Properties Palette
jeeenyuss
Hello,
A co-worker was working on a project, and for some reason, the "Phasing" portion of the properties palette disappeared.  Another co-worker was in the same project, but they could use the "Phasing" portion of the properties palette.  Does anyone have any idea why this would happen?  I literally have no idea why that would happen.
Thanks,
Colin
Tue, May 30, 2017 at 5:16:39 PM | Properties Palette
They both can't use the phasing on the same element or view at the same time.
Tue, May 30, 2017 at 6:46:57 PM | Properties Palette
jeeenyuss
That isn't the issue.  The issue is that one of them has the option to change the phasing, and the other one literally has no option to change the Phasing.  In the Properties Palette, where there is typically the Phasing section towards the bottom, the one person literally doesn't have the Phasing portion on their Properties Palette.
Wed, May 31, 2017 at 10:37:29 AM | Properties Palette
You need to tell us more.
Is the person working in the same file?
Is this possibly a dependent view?
Is the view controlled by a view template?  <<<< Look there.
Missing Orientation option (Project North/True North) in Properties Palette
Fri, Jan 29, 2016 at 11:23:52 AM
create a legend for my finish palette?
Thu, Jul 23, 2009 at 6:23:49 PM
Hide Instance Parameter ruled by formulas from the Property Palette
Thu, Nov 21, 2019 at 11:26:43 AM
put object ID field in the properties palette in the family editor
Mon, Oct 17, 2011 at 12:02:32 PM
Changing the Material [...] in Edit Assembly isn't bringing up Materials Palette
Fri, Mar 28, 2014 at 4:12:50 PM
Page generation time: 1.4958
