Forums >> General Discussion >> Revit Project Management >> DWG/DXF layers.
Mon, May 29, 2017 at 2:30:37 AM | DWG/DXF layers.
lukdab
When I'm linking DWG (or DXF saved with "select objects") Revit turns on all layers from the files.
Is there a way to import it as it is saved in Autocad (several layers turned off)?
Mon, May 29, 2017 at 9:23:07 AM | DWG/DXF layers.
From your HELP.
Wed, May 31, 2017 at 7:05:57 AM | DWG/DXF layers.
lukdab
It works! Thx!
LOL
import 3D model in DXF or DWG - how use it?
Mon, Oct 31, 2005 at 9:28:45 AM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:43 AM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
Are there any dwg /dxf files to download, all I see is *.rfa
Thu, Feb 5, 2009 at 10:12:18 AM
Toposurface Using Imported Instance
Thu, Oct 2, 2008 at 8:00:52 AM
Page generation time: 1.1458
