Forums >> Community >> Newbies >> In Place Mass control
Sun, May 28, 2017 at 12:33:10 PM | In Place Mass control
coastalclimbing
I am trying to use revit to design an indoor climbing wall and I am having a difficult time using revit to fully control the design. Mainly the design is comprised of large geometric flat triangles or quadrilaterals see attached image. I have an introductory understanding of massing. I am hoping someone could walk me throught the process of how they would approach this or provide any resources that would be beneficial.
Thanks in advance
Mon, May 29, 2017 at 9:29:31 PM | In Place Mass control
coastalclimbing
Realizing that my first post was a bit broad here are a few specifics issue I am running into:
· When I move into xray view or select a vertex and pull a side it creates irregular panels that are not flat. Is there a way to pull the vertex to preserve flat surfaces.
· I am not able to create more than one edge on a flat surface, I can't make an edge off of a created edge.
· When I divide the surface the surface, areas overlap where panels meet.  It is strange because the triangles are curved on the intersecting sides and not actually triangles.
· After I host walls onto the mass how should I deal with two intersecting walls to clean the overlapping walls?(see screen shot attachment) Is there a way to combine a mass in place and conceptual mass into one?
I have found that using sketchup is easier to create the mass but I feel like it shouldn't be. I am importing from Sketchup as a workaround but I would rather not because I like the massing environment better in revit as I can be more accurate with specific angles.
Any help is greatly appreciated.
Thanks
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
In-Place Mass Wirefram
Fri, Jan 11, 2013 at 8:47:32 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
adding control points on a mass model
Fri, Oct 15, 2010 at 11:08:17 PM
gable mass in place model
Mon, Jan 16, 2012 at 6:41:13 PM
14
Page generation time: 0.3748
